December 7, 2010, 11:36 |
Wind tunnel boundary conditions
Stef
Rep Power: 15 |
I am modeling a closed circuit wind tunnel in FLUENT. To simulate the fan, I have introduced a "cut" in the tunnel, assigning one of these edges as velocity inlet and the other as pressure outlet.
I am doing a thermal analysis of the tunnel, and want to see how the temperature changes over time as air flow through it. How do I go about doing this? I want the air coming out of the pressure outlet to go back into the tunnel at the velocity inlet. How can I do this so I can proceed with my transient model? Please help!! Thanks |
December 7, 2010, 22:39 |
Rep Power: 17 |
you will be able to see the temperature diff. dT between inlet/outlet
say, T_out(1) = T_in(1) + dT If air is recycled, T_out(2) = Tin(1) + 2*dT wouldn't this be enough, if u interested only in the temperature ? |
December 8, 2010, 12:25 |
Stef
Rep Power: 15 |
Thanks for your reply. I was considering this too, but I want to see how much time it will take for the air to be cooled to a certain temperature. Is there a way to see how long it takes the air to go thought one cycle (from the inlet to the outlet)?
boundary condition, fluent, temperature, wind tunnel |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
maintaining a logarithmic velocity distribution | Morten Andersen | CFX | 1 | January 8, 2007 11:37 |
Simulating a Göttingen type wind tunnel in FLUENT | Chris | FLUENT | 3 | December 4, 2006 17:33 |
Boundary conditions for a flame burning with wind | David | Main CFD Forum | 2 | February 4, 2005 05:59 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
