[Sponsors] | |||||
#1 | |
alireza razeghi
Rep Power: 4 ![]() |
hello
when i open the gambit i encounter the error : Quote:
this happened when i uninstalled gambit and then installed it even i installed the exeed 2007 powersuite several times but the problem exists ! |
Rep Power: 5 ![]() |
if you are using windows 7 you have to install exceed 2008. Also, check whether your windows is 64 or 32 bit so you can install the correct version of exceed.
hope it helps |
alireza razeghi
thanks
what is the best version of exceed for win xp in 32 bit pc? |
I believe it is exceed 2006.
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| gambit opening error | patiludayv | ANSYS Meshing & Geometry | 0 | March 11, 2010 04:29 |
| help for opening gambit file n Fluent..... | rizwan | FLUENT | 1 | March 22, 2009 23:41 |
| problem with opening gambit after upgrade windows | Baker Saleem | FLUENT | 4 | November 5, 2008 03:46 |
| opening a gambit file | Kabo | FLUENT | 1 | October 4, 2007 15:01 |
| Opening a mesh file in gambit | Vidya Raja | FLUENT | 17 | September 30, 2006 02:43 |
