-   -   Urgent; parallel processing in fluent 12 (http://www.cfd-online.com/Forums/fluent/83392-urgent-parallel-processing-fluent-12-a.html)
Mansureh December 27, 2010 03:09
Hello every body
I want to do parallel processing in Fluent 12, but when I launch fluent 12 and choose parallel option, Fluent gives following error:
Loading "D:\PROGRA~1\ANSYSI~1\v120\fluent\fluent12.0.16\li b\flprim1119.dmp"
Done.
Host spawning Node 0 on machine "chemeng-db7ca10" (win64).
999999: mpt_get_dot_address: warning: chemeng-db7ca10 -> 127.0.0.1. Check your system network configuration!
You can press CTRL+C to stop the startup process!
WARNING: No cached password or password provided.
use '-pass' or '-cache' to provide password
mpid: Cannot connect to mpirun (0.0.0.0, 1126): Unknown error
connect_mpirun failed
What should I do?
thanks for any help
skinnyfluid January 18, 2011 08:51
Mansureh,
which Number of Processes you setup?
abbott.hn September 24, 2012 04:26
i got the same problem
Originally Posted by Mansureh (Post 288539)
Hello every body
Done.
What should I do?
thanks for any help
i have got the same problem, some guys said that this would be ok if i plug in the network line ,but what's the real reason ? should ansys fluent work at internet enviroment?
mashiro September 24, 2012 08:03
turn off your fire wall.
shk12345 September 25, 2012 11:12
Try to make a server machine and the other clients machines and then connect them in a lan.
Then install fluent om the server and install mpinch client on the client.
Then try to run it
Hope that will work.
