January 5, 2011, 17:30 |
normal unit outward vector to the wall
YuanLiu
I am tring to implement a wall lubrication force for multiphase flow.Thus, the unit vector normal of the nearest wall is needed. Does anyone know how i can access it for my UDF?
Thanks! |
January 31, 2011, 08:46 |
There are two ways:
1. You can extract the face area vector which is a surface normal vector that points outwards from the domain and has a magnitude equal to the area of the wall cell face, you would then divide it by the magnitude of the vector to get a unit normal vector: F_AREA(A,f,t); where A is a vector with 2 elements if 2D simulation, 3 elements if 3D. You can use the ND_ND function to automatically size it to 2 or 3D. For example, the declaration of A would be "real A[ND_ND];" f is the face index for which the face area vector will be extracted (type: face_t) t is the thread index of the boundary surface (type: Thread) you can then calculate the magnitude of the vector with the NV macro: real AMag=NV_MAG(A); Then calculate the the unit normal vector as: A[0]=A[0]/AMag; A[1]=A[1]/AMag; A[2]=A[2]/AMag; 2: Use the BOUNDARY_FACE_GEOMETRY macro which explicitly gives you the unit normal vector (along with a bunch of other data on the boundary face): BOUNDARY_FACE_GEOMETRY(f,t,A,ds,es,A_by_es,dr0) f is the face index (type face_t) t is the thread index (type Thread) A is the the area normal vector (same as above type real with ND_ND elements) ds is the distance from the boundary face centroid to the cell centroid (type real) es is the unit normal vector in the direction from the cell centroid to the boundary face centroid (i.e. out of the domain) (type real vector with ND_ND elements) A_by_es is the dot product of the area normal vector with itself divided by the dot product of the area normal vector with the unit normal vector (type real) dr0 is a vector that connects the centroid of the cell to the boundary face centroid (i.e. es multiplied by ds) (type real vector with ND_ND elements) Hope that helps |
help with wall functions | Nick Georgiadis | Main CFD Forum | 10 | January 17, 2017 10:03 |
Wall Normal Temperature Gradient | Daniel Tanner | FLUENT | 6 | September 20, 2015 13:10 |
outward normal | Prem Venugopal | Main CFD Forum | 6 | July 26, 2004 04:20 |
Wall function in adverse pressure gradients | stephane baralon | Main CFD Forum | 11 | September 2, 1999 04:05 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
