March 18, 2013, 10:35 |
SR_RATE not getting compiled
Andhra Pradesh
Rep Power: 13 |
The following is the surface reaction rate that i want to input to the simulation
#include "udf.h" #define R 8.314 #define p 101325 #define pi 3.14159 DEFINE_SR_RATE(my_rate,f,t,r,mw,yi,rr) { Thread *t0 = t -> t0; cell_t c0=F_C0(f,t); real co = yi[0]; real h2o = yi[1]; real co2 = yi[2]; real h2 = yi[3]; real n2 = yi[4]; real ar = yi[5]; real rho_w = 1.0, T_w, sd=2.49045e-5; real xco = 1.0, xh2o = 1.0, xco2 = 1.0, xh2 = 1.0, xn2 = 1.0; real pco, ph2o, pco2, ph2, pn2, thetapt=1.0; real k1, k2,k3,k4,k5,k6,k7,k8,k9, k10,k11,k12, k13,k14,k15,k16,k17,k18,K1eq,K2eq,K3eq,K4eq,K5eq,K 6eq,K7eq,K8eq; real ratedecomp,rateform, rate; T_w = F_T(f,t); rho_w = C_R(c0,t0)*C_T(c0,t0)/T_w; h2o *= rho_w/mw[1]; co2 *= rho_w/mw[2]; co *= rho_w/mw[0]; h2 *= rho_w/mw[3]; n2 *= rho_w/mw[4]; ar *= rho_w/mw[5]; xn2 = n2/(n2+h2+co2+co+h2o+ar); xh2 = h2/(n2+h2+co2+co+h2o+ar); xco2 = co2/(n2+h2+co2+co+h2o+ar); xco = co/(n2+h2+co2+co+h2o+ar); xh2o = h2o/(n2+h2+co2+co+h2o+ar); pn2 = xn2*p; ph2 = xh2*p; ph2o = xh2o*p; pco = xco*p; pco2 = xco2*p; k1 = (0.129/(R*T_w))*(sqrt((R*T_w)/(2*pi*mw[3])))*(pow((T_w/300),0.858)); k2 = (7.95*1e12*sd)*(pow((T_w/300),-0.001))*exp(((-21.76 + (2.56*(T_w/300)))*4185.8)/(R*T_w)); k3 = (9.36*1e12*sd)*(pow((T_w/300),-0.118))*exp(((-17.404 - (0.38*(T_w/300)))*4185.8)/(R*T_w)); k4 = (9.99*1e12*sd)*(pow((T_w/300),-1.049))*exp(((-13.836 + (0.92*(T_w/300)))*4185.8)/(R*T_w)); k5 = (0.108/(R*T_w))*(sqrt((R*T_w)/(2*pi*mw[1])))*(pow((T_w/300),1.162)); k6 = (2.03*1e12*sd)*(pow((T_w/300),1.372))*exp(((-11.5225 + (5*T_w))*4185.8)/(R*T_w)); k7 = (1.0/(R*T_w))*(sqrt((R*T_w)/(2*pi*mw[0])))*(pow((T_w/300),0.000)); k8 = (5.66*1e15*sd)*(pow((T_w/300),-0.5))*exp(((-28.6 + (4*T_w))*4185.8)/(R*T_w)); k9 = (0.195/(R*T_w))*(sqrt((R*T_w)/(2*pi*mw[2])))*(pow((T_w/300),0.250)); k10 = (2.63*1e12*sd)*(pow((T_w/300),-0.250))*exp(((4.8- (0.004*T_w))*4185.8)/(R*T_w)); k11 = (8.03*1e08*sd)*(pow((T_w/300),-0.531))*exp(((-9.36 + (0.28*(T_w/300)))*4185.8)/(R*T_w)); k12 = (1.25*1e09*sd)*(pow((T_w/300),0.531))*exp(((-10.021 + (0.38*(T_w/300)))*4185.8)/(R*T_w)); k13 = (8.43*1e08*sd)*(pow((T_w/300),0.024))*exp(((-9.01 - (0.00782*(T_w/300)))*4185.8)/(R*T_w)); k14 = (1.19*1e09*sd)*(pow((T_w/300),-0.024))*exp(((-10.46 + (0.67*(T_w/300)))*4185.8)/(R*T_w)); k15 = (1.06*1e11*sd)*(pow((T_w/300),0.549))*exp(((-1.1 + (0.036*(T_w/300)))*4185.8)/(R*T_w)); k16 = (9.45*1e10*sd)*(pow((T_w/300),-0.549))*exp(((-2.22 + (0.62*(T_w/300)))*4185.8)/(R*T_w)); k17 = (1.1*1e11*sd)*(pow((T_w/300),0.492))*exp(((-17.394 - (0.00136*(T_w/300)))*4185.8)/(R*T_w)); k18 = (9.07*1e10*sd)*(pow((T_w/300),-0.492))*exp(((-12.43 + (0.62*(T_w/300)))*4185.8)/(R*T_w)); K1eq = k1/k2; K2eq = k3/k4; K3eq = k5/k6; K4eq = k7/k8; K5eq = k10/k9; K6eq = k11/k12; K7eq = k14/k13; K8eq = k15/k16; thetapt=(1/(1+(K3eq*ph2o)+sqrt((ph2/K1eq))+(pco2/K5eq)+(K2eq*K3eq*ph2o*(sqrt((K1eq/ph2))))+(K4eq*pco2)+(((K5eq*K2eq*K3eq*ph2o*pco2)/K8eq)*(sqrt((ph2/K1eq)))))); rateform = (pow(thetapt,2))*(k17*K4eq*K3eq*pco2*ph2o); if (STREQ(r->name, "reaction-1")) { *rr = 471*(rateform)/1000; C_UDMI(c0,t0,0) = *rr; } } Firstly could someone please go through this and comment if my code is correct or not? I compiled no errors in code. After compiling i hooked it and used one used defined memory But after performing iterations the outlet composition is same as inlet composition. essentially the simulation is not identifying the UDF. Another doubt that i have is should i compile the udf first or define everything else and then compile it and hook it? if needed i can share the simulation file with you. Thanking you, V.Vismayie |
Interepreted Vs. Compiled UDFs | Antonis | Fluent UDF and Scheme Programming | 10 | March 22, 2018 11:15 |
Odd error when using OpenFOAM compiled with --march=native | JLight | OpenFOAM Running, Solving & CFD | 0 | October 15, 2012 23:36 |
Using compiled UDF:s in different Fluent versions | S H | FLUENT | 1 | September 12, 2007 03:40 |
how to compile compiled UDF? | AVINASH | FLUENT | 3 | January 19, 2007 04:04 |
DEFINE_CG_MOTION Interpreted or Compiled? | Aussie Shane | FLUENT | 0 | April 20, 2006 04:50 |
