January 6, 2011, 20:35 |
Pressure Boundary Condition
hamid
Rep Power: 15 |
Hi
What is the definition of pressure inlet and pressure outlet in Fluent, I am going to simulate a cylinder with the same amount of pressure inlet and pressure outlet, as far as I understand because the pressure at both sides of the cylinder are identical there shouldn’t be any flow and the velocity should be zero, but there is a flow from inlet to outlet with non-zero speed, It happens even when the pressure outlet is higher than pressure inlet, Could anybody let me know why? Thanks very much in advance |
January 7, 2011, 03:06 |
Bernhard
Rep Power: 21 |
Did you have a look at the Fluent Users Guide? Boundary conditions and the solved equations are described in some detail there.
January 7, 2011, 05:30 |
hamid
Rep Power: 15 |
Thanks for reply,
Yes, but still abit confused, in my feeling when the pressure inlet and outlet are the same then it means that there is not delta P and there wont be no motion, I Know this is wrong (in fluent)but I don’t know why? |
January 7, 2011, 08:19 |
hamid
Rep Power: 15 |
If anybody is aware of the answer please kindly share,
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Pressure boundary condition | C-H Kuo | Main CFD Forum | 18 | September 16, 2016 03:19 |
how can i give a boundary condition with pressure and velocity together | akhenathon | FLUENT | 6 | April 24, 2012 18:32 |
Pressure Boundary condition | abishek | FLUENT | 1 | July 28, 2008 08:14 |
Pressure boundary condition and real gas | Pifou | FLUENT | 0 | July 19, 2005 11:42 |
