UDF: temperature dependent BC
I am attempting to write a UDF such that the boundary condition of a wall has non-zero heat flux (eg: heater being switched on) when the temperature of a specific point in my model falls below a certain value and a zero heat flux otherwise. I guess using DEFINE_ADJUST to read the temperature of that point and DEFINE PROFILE to specify the BC. Am i going in the right direction? Also, how do I obtain the temperature of that specific point? I know the coordinates of the point. Many thanks. Cheers, EH |
To view the temperature u can use monitor< temperature at that specific point. THis will be display temperature at that point at every iteration Hope this will help you |
I guess the main issue is how to obtain the temperature of a point using UDF or at least link the temperature from the monitored point to my UDF. Thanks. |
hi,
to do this , you can separate the element in which your specific point is. after that, the separated element get different thread ID and you can use it easily. |
When you say separate the element, do you mean doing it in the model development stage? Or is this done by writing a UDF for it? If yes, could you guide or point me to some sources that can help me in this? |
hi EH,
you can do that in FLUENT GUI: 1)adapt->region : specify a volume (as small as possible.try to capture one cell) with sphere or hex or ... . and mark this volume that contain your point. (do not adapt it ,just mark) 2)grid->separate->cells : here you can separate your marked volumes. 3)define->boundary conditions : here you can see your separated volume's ID (you need that in your UDF) |
amirreza_m thanks a lot about this tip!!!!
For years i was just making loops in my UDFs over all cells!!!! Thank a lot! |
