setting of level set method as initial condition
Old   April 7, 2011, 11:18
Default setting of level set method as initial condition
YG Kim
sooroo3 is on a distinguished road
I use the Ansys 13, and have several quastion as below.
First, when using coupled Level set with the VOF model, how i set the initial condition? is it ok for level set function to set zero in intialization?
second, is it possible to sovle the VOF+Level set with Solidification/melting model together?
Please give me advice.
Thanks
sooroo3 is offline   Reply With Quote
Old   December 13, 2011, 06:40
gtliang
dutliang is on a distinguished road
I have the question too, and it makes me very puzzled.
If you have the answer, please tell me soon.
Thank you very much!
dutliang is offline   Reply With Quote
Old   December 13, 2011, 18:19
qingming.liu
peterliu is on a distinguished road
me too, and every time i got the following error
Primitive error at node 0: fill cell VOF distance: invalid number of nodes on the face.
do you have the same problem?
peterliu is offline   Reply With Quote
Old   January 7, 2015, 19:15
navid
ndabir is on a distinguished road
Did you solve the problem? Did you figure out how to set initial conditions of coupled level set and VOF method in Ansys?
ndabir is offline   Reply With Quote
Old   July 31, 2018, 04:20
Muhammad Sufyan
Sufyan is on a distinguished road
Can you please help me.. I have same question .. How to initialize the level-set field ..i have defined the volume fraction correctly for my problem.
1- if I only use vof model. (explicit- geo-reconstruction) residual converges and simulation runs and I am getting results.
2- I have to run simulation with CLSVOF in FLUENT. when i select this option and keeping all other parameters same, my residual for ls-function does not change. I assume I have not initialized Level-set field as I did in my in-house code.
Please describe the method to initialize the level set field in fluent.
thanks
SUFI
Sufyan is offline   Reply With Quote
Darcy-Forchheimer law for specifying Porous Zones Ger_US OpenFOAM Running, Solving & CFD 37 April 10, 2022 03:38
Compressible Nozzle Flow sebastian OpenFOAM Running, Solving & CFD 14 September 21, 2016 10:47
Error log vw.cfd OpenFOAM 6 August 7, 2009 05:44
Unknown error sivakumar OpenFOAM Pre-Processing 9 September 9, 2008 12:53
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
