-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   species transport in FLUENT (https://www.cfd-online.com/Forums/fluent/83834-species-transport-fluent.html)
arnab January 12, 2011 19:11
Hi all,
I am trying to simulate coal gasification using species transport, finite rate chemistry/eddy dissipation model....
These are the reactions I want to include:
Heterogeneous Reactions:
C(s)+0.5O2 --> CO
C(s)+CO2 --> 2CO
C(s)+H2O --> CO+H2
Homogeneous Reactions:
Volatiles+O2 --> CO2+H2O
CO+0.5O2 --> CO2
CO+H2O --> CO2+H2
CO2+H2 --> CO2+H2O
H2+0.5O2 --> H2O
I have created coal-volatiles-air as the mixture material...but having confusion over what species to include in the mixture /fluid /solid under the materials tab...I am using FLUENT 12.1 version...
could anyone suggest on this...plz help....
thanks
Arnab
nmanic January 15, 2011 11:28
How You introduce fuel into domain? Are You using DPM model for injecting coal particles?
arnab January 15, 2011 11:33
yes..I am using DPM for coal injection..(group/surface)..when I include the Volumetric and particle surface reactions..I can input the proximate and ultimate analysis, HHV values using the coal calculator in species transport..
thanks..
nmanic January 15, 2011 13:57
Yes, I have the similar problem, and unfortunatley I didn't found solution yet. I model biomass pelet combustion with same models, as You used (SPECIES TRANSPORT, DPM, Injection fuel particle). My problem is to find out how to "control" (I mean to fast up and slow down) reactions in gas phase and heterogenous reactions. I try to change preexponetial factor and activation energy for these reactions but nothing yet, I don't have logical solutions. For example I want to slow down burning CO to CO2, because I get very small amount of CO in my outflow. Of course temeparture and turbulency also influnced on these. I try to change them also, but nothing significantly happened.
I'll keep trying and I'll inform You, if I make any progress.
Nikolopoulos January 21, 2011 12:24
You have enabled multiple char reactions?
In fluid/solid you should include C(s) (it is in fluent library)
Best Regards,
Nikolopoulos Aristeidis
nmanic January 21, 2011 16:44
Best Regards,
Thanks for joining in topic!
OK! I include C(s) (which represent char) in my model, but how can I enable "multiple char reactions". Does it particle surface reactions?
Everyone mention UDF for heterogeneous reactions. Does it necessery? I'm not so good in writing UDFs. :confused:
Can I bypass it in this model?:D
Nikolopoulos January 22, 2011 08:14
multiple char reactions is selected in the panel of materials in the drop down list for char burnout model.
Yes you can avoid UDF. Fluent creates a panel for heterogeneous reactions for C<s> similar to homogeneous reactions.
However if the rate expression is complicated you will probably need a UDF.
I'm home and i don't have fluent at home. I hope i remember correctly
pmechz April 12, 2016 07:36
hi ...
would u plz help me?
I want to simulate mixing of Two fluids.
but by using species transport model, how can i allocate constant value to properties of each component?
best regard
SJSW October 20, 2016 08:40
Hi~
Are heterogeneous reactions set up through "Phase Interaction→Reaction"?
Thank you!
