how to get cd,cl values of an airfoil correctly?
I have worked on these for about two weeks,but i just can't get these values correctly.If i plot these values vs AOA,some particular points(AOA=40-60 or even more)will not go smoothly,and had a rapid change.
I know how a cd,cl graph may look like,but i don't know what the problem is.I have tried changing the viscous models(spalart-allramas,k-epsilon, k-w and rsm)or decrease the under-relaxation,but it didn't work.Now i will try to get my physical model bigger(inlet and outlet longer),but what i would like to know is,there are a lot of papers that ploted cd,cl values,some of them used fluent,but i don't know how to get a smooth graph.I just get a overall similar graph,but under some AOA,the simulation didn't get a converge solution,even i set iterations to more than 30000.I think many people here knows how to do this simulation,so could anyone give me some advise, thank you. my setting: 2-D steady airfoil=s823 chord length=1m viscous=k-epsilon wall function=standard Re=200000 pressure velocity coupling=SIMPLE decretization=all second order or second order upwind |
Try to use an unsteady solver for big AOA
