Home > Forums > FLUENT
DEFINE_ADJUST udf problem
Old   January 16, 2011, 17:44
Default DEFINE_ADJUST udf problem
Matevz Dular
mateus is on a distinguished road
I'm writing an udf where I first store temperature at the end of each time step. This part work fine - I do it like this:
DEFINE_EXECUTE_AT_END(execute_at_end)
Domain *d;
Thread *t;
cell_t c;
d = Get_Domain(1);
thread_loop_c (t,d)
if (FLUID_THREAD_P(t))
begin_c_loop (c,t)
C_UDMI(c,t,0) = C_T(c,t);
end_c_loop (c,t)
Then in the second part I want to divide current (not converged) temperature with the converged one from the last time step (this one is stored under C_UDMI(c,t,0)).
C_UDMI(c,t,1) = C_UDMI(c,t,0)/C_T(c,t);
To check if it works fluent should give a value of 1 all over domain if I calculate this part in the last (converged) iteration of the new time step, right? - that's because also DEFINE_EXECUTE_AT_END macro will calculate C_UDMI(c,t,0) at this point. I hope I'm making some sense and that it's clear what I'm doing.
If I use DEFINE_ADJUST macro it doesn't give the correct result (1 all over domain at the end of the time step). But if I use DEFINE_EXECUTE_ON_DEMAND it does. It also gives the correct result if I use custom field function tool in Fluent GUI - but this way is not useful for me because I need this variable to define material property further on...
Thanks for any comments and ideas!
Mateus
mateus is offline   Reply With Quote
Thread Tools
Trackbacks are On
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 32 May 8, 2015 06:05
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 04:56
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 06:56
udf compiling problem akr FLUENT 3 August 22, 2007 07:14
UDF problem chiseung FLUENT 4 January 10, 2002 10:58
