Change cell zone index/thread during simulation
I am modelling a shrinking porous zone within a fluid zone. The porous zone will be shrinking as the simulation proceeds. The porosity change is both time and space dependent and will change from 0 to 1 during the simulation. Cells nearest the fluid-porous interface will reach 1 the quickest. Basically, when the porosity in a cell reaches 1 I want to change the cell zone index to that of the fluid zone. This will effectively cause the porous zone to shrink. I realise I could just change the momentum sinks to 0 which would basically do the same thing but this approach is necessary as I want to be able to distinguish between the porous and fluid threads in order to implement a reaction on the surface of the porous zone. I have tried the following but it hasn't worked: static int porous_zone_ID = 6; /*points to the porous thread*/ static int fluid_zone_ID = 5; /*points to the fluid thread*/ DEFINE_ADJUST(adjust_thread, domain) { cell_t c; Thread *tp; /*pointer to porous zone thread*/ Thread *tf; /*pointer to fluid zone thread*/ int zone_ID; real x[ND_ND]; tp = Lookup_Thread(domain, porous_zone_ID); tf = Lookup_Thread(domain, fluid_zone_ID); begin_c_loop_int (c, tp) { if (C_UDMI(c,tp,0) = 1.0) /*the porosity in each cell has been stored in UDM 0 from a different UDF*/ { zone_ID = THREAD_ID(tf); /*should change the cell zone to that of the fluid zone*/ /*Note: the macro above is the opposite to the lookup thread macro*/ } } end_c_loop_int (c,tp) } I have also tried hardcoding the zone_ID (i.e. zone_ID = 5), but this hasn't worked either. It appears that the zone_ID macro doesn't change the index in the solver but can only call it. Has anyone got any ideas? It'd be much appreciated. Thanks, Neil |
