Accelerate flow in one direction
Old   January 17, 2011, 12:44
Default Accelerate flow in one direction
Jan Falk Rusås
JanR is on a distinguished road
Dear All,
I have a domain which is very long in one direction, maybe factor >> 1000 compared two the two other directions. The transport of information seems to be very slow from inlet to outlet.
Is there a logic an easy way of accelerating the solution in one direction, such that the solver used less "sweeps" in the short direction and more in the long direction.
Thanks in advance
Jan
JanR is offline   Reply With Quote
Old   January 18, 2011, 18:15
red_lemon is on a distinguished road
Initialise or patch it realistically to start off (i.e. not zero everywhere) using the inlet zone.
Maybe run a 2d simulation instead?
Use high aspect ratio cells stretched in stream wise direction.
red_lemon is offline   Reply With Quote
Old   January 19, 2011, 15:52
Jan Falk Rusås
Thanks for the advice red Lemon. I have al ready done all that.
In the very old CFX it was posssible to control the number of sweps in each direction and by that a control of the time spend on calculating the flow in each direction. I think there is a similar option in Fluent, Cycle, but I don't understand it nor have experience
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
a variable flow (in speed and direction) as inlet velocity teskio FLUENT 1 July 5, 2009 08:59
shear force and flow direction ingear Siemens 0 March 3, 2006 14:13
Can 'shock waves' occur in viscous fluid flows? diaw Main CFD Forum 104 February 16, 2006 05:44
mass flow inlet Denis Tschumperle FLUENT 7 August 9, 2000 02:19
