Parallel computing
Has anyone used 2 or more Laptops or desktops to solve your problem using Fluent. Plz let me know if there any tutorials or can some provide direct help....
parallel computing
I have asimilar question. I have completely installed Ansys 12.1. My computer is core 2 quad. however when I use ansys batch and run an udf code it uses only one core. I have installed Hp-MPI and I have some problem with its setting. I would be grate if some one help me in this way
I'll try this multi-processing next week!
I think that in the batch file you should put the IP of the other computer as many times as the Computing nodes that you want to spawn in this PC |
You can always create a small cluster from a 2-3 computers, personally I've worked on a CentOS based cluster with Fluent 6.3.
For more information search the net for Bewoulf based clusters: http://www.beowulf.org/ Do |
