January 23, 2011, 09:33 |
Velocity gradient tensor
kumaran
Hello there,
could anyone suggest how to extract second invariant of the velocity gradient tensor from fluent? I am using Fluent v12 Thanks |
January 24, 2011, 07:06 |
Nikolopoulos Aristeidis
Yes i know how you should do it!
I did it for calculation of frictional solid viscocity in Euler -Eule granular material simulation. If you want the IId in a UDF you should obtain the derivatives of velocity in each direction (C_DUDX(cell, thread), C_DVDX(cell, thread), C_DWDX(cell, thread) etc. (check the command in the UDF manual). and then just use the formula. ND_ND parameter will help you in order to obtain a code that works for 2-D and 3-D. If you want the IId just for plotting define a custom field function (Fluent -> Define -> define a custom field function ) Be careful in this: Are you sure that you want to calculate the second invariant of gradU??? Or you want the second invariant of the deviatoric part of rate-of-strain tensor? |
January 25, 2011, 07:56 |
kumaran
hello Nikolopoulos,
thank you for your response. I am looking for the IId of gad U to look at the coherent vortices in 3D. i am not that familiar with the UDF.. do you mind sharing the UDF file that has the skeleton? so that i can try to modify it ? Thanks |
January 26, 2011, 01:31 |
Do you want it only for post process?
January 26, 2011, 02:15 |
kumaran
hi,
yes. i want only for post process to see the streamwise vortices in teh midsection of the domain Thanks |
January 25, 2012, 03:00 |
udf for velocity tensor
studen
hi kumaran and nick, i also need to see the velocity tensor for my simulation can u pls share the udf file.
regards and thnks in advance |
Transformation of a cartesian velocity gradient volTensorField to cylindrical coord. | alexey7783 | OpenFOAM | 5 | April 26, 2012 18:29 |
About deformation gradient tensor | ZHANG | Main CFD Forum | 0 | June 18, 2007 12:51 |
UDF sample for velocity gradient | J.Y.Shin | FLUENT | 2 | January 19, 2007 18:04 |
velocity gradient | Merinadica | FLUENT | 0 | December 16, 2006 04:53 |
Second invariant of velocity Gradient | Funda | Siemens | 2 | September 28, 2004 06:18 |
