unsteady simulation
Old   February 4, 2011, 08:43
Default unsteady simulation
hamid
hamid1 is on a distinguished road
Hello guys
for unsteady simulation should one first have a converged solution in steady and then shift to unsteady or thats is not necessarily compulsory?
hamid1 is offline   Reply With Quote
Old   February 4, 2011, 09:55
Amir's Avatar
Amir
Amir is on a distinguished road
Hi hamid,
it's not necessary to initialize unsteady problem with converged steady one.
but in some special cases like small perturbations and ... it helps you to have fewer iterations per time steps.
Amir is offline   Reply With Quote
Old   February 4, 2011, 10:41
hamid
thanks Amir,
but if I dont have a steady converged initialized solution does it mean that I cant rely on my unsteady simulation at the first few steps of time duration?
Old   February 4, 2011, 12:47
Amir's Avatar
Amir
your answer in unsteady simulation is reliable if and only if the residuals after each time step satisfy your convergence criteria. but as I said before , in some special cases if you have a good initialization data field , the convergence criteria may takes place in fewer iteration per time step . (this tip doesn't change the generality of the first sentence)
Old   February 4, 2011, 15:37
Farhan
itsuetian@hotmail.com is on a distinguished road
For unsteady simulation it is not mandatory to have converged solution in steady and then shift to unsteady simulation.You can start with unsteady simulation and can rely on that.I have worked on the unsteady simulation of flow arround cylinders and it gives reliable results.
itsuetian@hotmail.com is offline   Reply With Quote
Adding heat source to chtMultiRegionFoam maddalena OpenFOAM Programming & Development 61 February 17, 2018 08:33
Unsteady vs Steady simulation - any difference? Sally Main CFD Forum 16 December 16, 2005 09:15
About unsteady flow simulation Ji Fidelity CFD 3 June 10, 2003 10:04
Procedure to run unsteady simulation? STN Main CFD Forum 2 February 16, 2002 04:37
1D simulation of unsteady gas flows in pipelines Andrew Chernousov Main CFD Forum 1 September 4, 1998 23:42
