-   -   Meshing problem Gambit-fluent (http://www.cfd-online.com/Forums/fluent/84358-meshing-problem-gambit-fluent.html)
ajay January 27, 2011 01:38
Hello to all,
I want to do analysis of Flow through pipe using gambit-fluent software. Air as fluid. The fluid is coming form 5 mm diameter jet. It flow (V=184 m/s ) in 1.3m long pipe of 5.5 cm diameter pipe with a bend at the end.
1. I cannot considered a axi-symmetry problem. But yes symmetrical can be considered. This gives message large negative volume.
2. If i make fine mesh near jet and pipe, large no of volume is generated.
3. Controlling mesh by giving interval counts on edge, gives me unstable solution's.
4. controlling skewness, gives me large aspect ratio mesh.
Looking for your kind help.
Ajay
-mAx- January 28, 2011 00:51
avoid negative volume.
In gambit you can check where they are: examine mesh /volume....
tobino January 28, 2011 00:57
You would better calculate with scale mode.
chandrasekhar.gullapalli January 28, 2011 01:42
Can you send a snap shot of your problem, with mesh for better understanding of problem.
