January 27, 2011, 01:38 |
Meshing problem Gambit-fluent
ajaymakawana@yahoo.com
Hello to all,
I want to do analysis of Flow through pipe using gambit-fluent software. Air as fluid. The fluid is coming form 5 mm diameter jet. It flow (V=184 m/s ) in 1.3m long pipe of 5.5 cm diameter pipe with a bend at the end. 1. I cannot considered a axi-symmetry problem. But yes symmetrical can be considered. This gives message large negative volume. 2. If i make fine mesh near jet and pipe, large no of volume is generated. 3. Controlling mesh by giving interval counts on edge, gives me unstable solution's. 4. controlling skewness, gives me large aspect ratio mesh. Looking for your kind help. Ajay |
January 28, 2011, 00:51 |
Maxime Perelli
Rep Power: 41 |
avoid negative volume.
In gambit you can check where they are: examine mesh /volume....
In memory of my friend Hervé: CFD engineer & freerider |
January 28, 2011, 00:57 |
Tobino
Rep Power: 15 |
You would better calculate with scale mode.
January 28, 2011, 01:42 |
Chandrasekhar G
Rep Power: 15 |
Can you send a snap shot of your problem, with mesh for better understanding of problem.
Converting Fluent mesh files to Gambit neutral files | samuelkc | ANSYS Meshing & Geometry | 9 | April 21, 2021 06:28 |
Fluent simulation problem & Gambit "database"error | Chase Estrin | FLUENT | 4 | February 21, 2013 04:15 |
[GAMBIT] Desperate student needs help meshing 3D GAMBIT model - please help! | lau06165 | ANSYS Meshing & Geometry | 1 | March 22, 2010 01:09 |
problem with gambit unsymmetrical meshing | meenakshi | FLUENT | 1 | March 28, 2008 12:46 |
GAMBIT problem with 3D Boundary Layer when meshing | Anthony Haroutunian | FLUENT | 2 | March 26, 2008 02:02 |
