January 30, 2011, 07:01 |
How to draw U-Pipe in 3D
Hi I need to draw a U pipe as 3D mesh in gambit and I donnot know how ? may somebody help me with it please?
Mariam Last edited by mariam.sara; January 30, 2011 at 07:25. |
January 31, 2011, 01:28 |
Maxime Perelli
Rep Power: 41 |
*create your U as edges
*create your pipe section (surface) *place one extremity of your edges-chain at center from your surface *create the volumes by sweeping your surface with edges (Volume/sweep surface)
In memory of my friend Hervé: CFD engineer & freerider |
January 31, 2011, 07:41 |
Thanky you max for your valuable reply. I am beginner with Gambit may you send me a JOU file for the steps you mentioned this will be more helpful to me.
Mariam |
January 31, 2011, 07:49 |
Maxime Perelli
Rep Power: 41 |
vertex create coordinates 0 0 0
vertex create coordinates 100 0 0 vertex create coordinates 100 100 0 vertex create coordinates 0 100 0 edge create straight "vertex.1" "vertex.2" edge create straight "vertex.2" "vertex.3" edge create straight "vertex.3" "vertex.4" edge create fillet "edge.1" "edge.2" parameters 0.79069168 0.17737705 radius \ 30 notrim edge create fillet "edge.2" "edge.3" parameters 0.85621269 0.11274796 radius \ 30 notrim edge split "edge.3" vertex "vertex.8" connected edge split "edge.2" vertex "vertex.7" connected edge split "edge.2" vertex "vertex.6" connected edge split "edge.1" vertex "vertex.5" connected edge delete "edge.3" "edge.7" "edge.2" "edge.9" lowertopology edge merge "edge.1" "edge.4" "edge.8" "edge.5" "edge.6" forced face create radius 20 yzplane circle volume create rotate "face.1" onedge "v_edge.9" draft 0 rounded window modify shade window modify noshade edge delete "v_edge.9" lowertopology
January 31, 2011, 08:10 |
max thanks for your effort. I failed to sweep the faces into volume, I chose face 1 & 3 and select path as edge I chose edge 12 then after i press apply this error appear to me:
ERRor: The chain to be swept is parallel to the path what i can do then? is my selecting of faces wrong? Mariam |
January 31, 2011, 08:15 |
Maxime Perelli
Rep Power: 41 |
did you run the journal file?
it should create your pipe automatically
January 31, 2011, 08:20 |
Yes I do but it not complete only there are two circles connected with line like U check it pls? see image
Maraim |
January 31, 2011, 08:37 |
Maxime Perelli
Rep Power: 41 |
enable shaded mode on (icon with grey block)
January 31, 2011, 08:44 |
hi again max I failed to find the shaded mode that you mentioned? may you send me illustrated picture for it ? Should I do this step before running the journal file to get the volume?
Mariam |
January 31, 2011, 08:48 |
Maxime Perelli
Rep Power: 41 |
this is just a display option (like light on/off)
January 31, 2011, 09:00 |
#11 |
Is it available with the sweap option or you mean with it the neighbor block? if the second there are several options to draw the volume like that appear on the image (see it pls) which one should i select to draw the volume? sorry to bother u
January 31, 2011, 09:09 |
#12 |
Maxime Perelli
Rep Power: 41 |
#13 |
Sorry max i found it at last thanks a lot. Now can i mesh this volume easily?
January 31, 2011, 09:21 |
#14 |
Maxime Perelli
Rep Power: 41 |
As you saw there is only one generatrice (line linking the 2 disks)
It will crash the mesh. So you can create a second generatrice. > edge split "edge.13" percentarclength 0.5 connected > edge split "edge.10" percentarclength 0.5 connected it will split the circle into 2 semi-circles, with a vertex in the middle Then split the surface with the 2 vertex. >face split "face.2" vertices "vertex.13" "vertex.14" Then you can go and mesh your volume (spacing 5), gambit will automatically select cooper scheme
January 31, 2011, 09:31 |
#15 |
max may you sent me the first journal file with adding the last steps. An error happened while i split face 2 with vertices 13 and 14?
Thanks again Mariam |
February 1, 2011, 00:47 |
#16 |
Maxime Perelli
Rep Power: 41 |
What kind of error?
February 1, 2011, 07:03 |
#17 |
Thank you max i succeded with drawing the mesh.
May 12, 2014, 15:38 |
#18 |
Rep Power: 11 |
30 notrim 0.79069168 for edge 1 and 0.17737705 for edge to or inverse ? |
How to draw pipe mesh | Ismael | FLUENT | 2 | March 3, 2007 16:27 |
how to draw velocity profile(in unstructure pipe ) | lenson | Siemens | 8 | November 19, 2005 06:13 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
