Low Speed Flow Boundary Conditions
Old   March 13, 2007, 05:32
Default Low Speed Flow Boundary Conditions
Paul Bateman
This is a question from a newbie CFD user regarding a problem that really has me stumped.
I have successfully used FLUENT in the past for transonic aerofoil and wing analysis using a compressible flow setup and the coupled solver. However, I'm now trying to simulate the flow around various 2D bodies at low speeds (e.g. 10 to 30 m/s at sea level) and small angles of attack. No matter what I try I seem to get x and y velocities that converge, but mass continuity gets "stuck" at about 10e-1 or 10e-2.
The flow field looks sensible, there are no "hot spots" in terms of velocity in the domain, and lift coefficient seems sensible(ish). Mass fluxes into the domain = mass fluxes out of the domain.
Mesh:
"Extended D" shaped domain with aerofoil at centre.
Boundaries are at least 50 chord's away from aerofoil. ~30000 elements.
I have tried:
1) unstructured tet mesh (with high quality elements)
2) Structured quad mesh
Boundary conditions:
Front of D & bottom of D - set to velocity inlet at 30 m/s with velocity components to give 2 degree AOA.
Top of D and back of D - set to pressure outlet with a pressure of 101325 Pa normal to boundary.
Aerofoil - set as a wall.
Solution set up:
Segregated Solver.
Incompressible flow.
Energy equation disabled.
Operating pressure set to 101325 Pa.
I have tried both first and second order upwind discretisation.
I have tried inviscid, laminar and turbulent solutions.
I have tried changing under relaxation of momentum with no improvement.
I don't think the problem is to do with grid resolution because it won't run inviscid. Plus, if I set up the same mesh as a transonic problem with the coupled solver and pressure far-field boundaries it converges nicely. I think it might be my selection of boundary conditions, but I don't have enough experience to know better.
If anyone has any pearls of wisdom to offer I will happily try anything. Thanks in advance for any help offered.
Paul
Old   March 14, 2007, 23:29
Default Re: Low Speed Flow Boundary Conditions
S Guha
Plot the mass flow values vs iteration at inlet and outlet. If it is straight (i.e. they dont have any gradients) and your mass flux report shows a difference of less than 0.5 % at inlet and outlet, then there is no necessity for decresaing your residuals i suppose. if it satisfies all these crtireion (as mentioned above) with larger residuals then it might mean it is possible......
Old   January 10, 2013, 13:01
Default Precision
Sheng
micro11sl is on a distinguished road
Are you using single precision?
Change it to double and try again...
micro11sl is offline   Reply With Quote
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
1D unsteady flow boundary and initial conditions Hooman Main CFD Forum 0 August 7, 2011 06:21
boundary conditions for 2D flow around a circle abcdef123 Main CFD Forum 0 April 21, 2010 02:26
3-D Compressible Flow Boundary Conditions Tyler FLUENT 4 February 5, 2009 19:58
Boundary Conditions Jan Ramboer Main CFD Forum 11 August 16, 1999 08:59
