UDF - accessing face variable problem
Hi all,
really appreciate your help. Im trying to create a UDF for velocity inlet. UDF was interpreted without any problems. Problem is, that Im just not able to access data from appropriate boundary condition (fatal signal, access violation) which I need in my equations. Problematic part of UDF: DEFINE_PROFILE(velocity_inlet, thread, index) { real x[ND_ND]; double y; face_t f; Thread *tf; ro = 1.225; begin_f_loop(f, thread) { F_CENTROID(x, f, thread); y = x[1]; density= F_R(f,tf); F_PROFILE(f, thread, index) = equation; } end_f_loop(f,thread) } Using Data_Valid_P() function, initialization, or if-loop function didnt help (probably my syntax was incorrect). What should I do? |
hai,
to access the face boundary, you need to include the thread identifier. use Lookup_thread(d,Zone_ID) where the zone ID is obtained from the boundary conditions panel. try these DEFINE_PROFILE(velocity_inlet, thread, index) { real x[ND_ND]; double y; face_t f; int Zone_ID=--- ; Thread *tf=Lookup_Thread(d,Zone_ID); Thread *tf; real ro = 1.225; begin_f_loop(f, thread) { F_CENTROID(x, f, thread); y = x[1]; density= F_R(f,tf); F_PROFILE(f, thread, index) = equation; } end_f_loop(f,thread) } |
Thank you very much for your help, now it works..:))
Complete version of solution looks like (if someone interested in): DEFINE_PROFILE(velocity_inlet, thread, index) { real x[ND_ND]; double y; face_t f; Thread *tf; int Zone_ID=--- ; real density; Domain *domain; domain = Get_Domain(1); tf=Lookup_Thread(d,Zone_ID); begin_f_loop(f, thread) { F_CENTROID(x, f, thread); y = x[1]; density= F_R(f,tf); F_PROFILE(f, thread, index) = equation; } end_f_loop(f,thread) } |
