Results N0012 with y+<65 or y+<15 ?
Old   February 4, 2011, 12:05
Default Results N0012 with y+<65 or y+<15 ?
ferranpm is on a distinguished road
Hello!
My test:
Profil NACA0012
Re=1M
alpha=15°
K-Omega SST with Trans. Flow
I read that when i use K-omega theory, i should have an y+<1. With my first mesh, I had an yplus < 65, and the profil is not in stall.
I use the "adapt" funtion to reduce the yplus. I used max. yplus=1, min. yplus=0. Then I iterate one more time, and now the profil is in stall (more accuracy?) and the yplus was < 15.
Which result has more accuracy? Can I use K-omega with yplus more than 1, or maybe should I use K-Epsylon?
Thank you!!
Ferran PM
ferranpm is offline   Reply With Quote
Old   February 5, 2011, 06:06
Hello again,
I read about K-Omega SST and with Trans. flow I need y+<1. Should I suppose that my results are not so good enough?
Thank you
Ferran
Old   February 5, 2011, 18:07
DoHander is on a distinguished road
y+ between 1 and 30 typically means bad results in Fluent, so your simulation with y+ < 15 is not to be trusted.
Do
DoHander is offline   Reply With Quote
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
Different Results from Fluent 5.5 and Fluent 6.0 Rajeev Kumar Singh FLUENT 6 December 19, 2010 11:33
validation of CFD results andy FLUENT 0 June 13, 2007 13:55
CFX cylinder or sphere benchmark results Mel CFX 1 August 8, 2005 18:47
benchmark results stefan Siemens 3 September 10, 2001 09:48
