Help modelling a 2D open channel
Old   February 11, 2011, 08:02
Default Help modelling a 2D open channel
egge24 is on a distinguished road
I'm new using fluent. I'm trying to model a 2D (top view) open channel flow, a water tank, with an actuator disk in the middle of the cross section, see Fig.-1, in order to evaluate de horizontal components of velocity. The tank is y=1.37m, x=5m, the actuator disk (with edge geometry) is y=0.1m.
I set up the model with the following boundary conditions for every edge:
  • Inlet: inlet velocity.
  • Outlet: pressure outlet.
  • Side walls: walls.
  • Actuator disk: porous jump. Porous medium thickness = 0.001m, pressure jump coef. = 0.5/m (I tried higher values but the results didn't change) and face permeability = default value 1e10mē.
  • The edges next to the actuator are set as interior.
The problem is that the result doesn't show any variations in the velocity components due to the interaction with the actuator disk, see Fig.-2.
Any suggestions?
Thank you!
Fig.-1 - Tank mesh, actuator disk in red.
Fig.-2 - Velocity magnitude results.
egge24 is offline   Reply With Quote
Old   February 11, 2011, 13:03
Amir's Avatar
Amir
Amir is on a distinguished road
first, you have open channel flow and phase changes occur in normal direction(z).
2D modeling is acceptable if actuator locate near free surface I think.
second, setting outlet as outflow may work.
Amir is offline   Reply With Quote
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
Modelling open channel flow. gizeh FLUENT 0 October 12, 2009 06:20
VOF modelling open channel river flow Matthew Roberts FLUENT 6 July 31, 2009 12:52
VOF modelling Open Channel flow Rodi FLUENT 2 August 11, 2007 13:15
Problem with VOF open channel modelling Biswanath Mahato FLUENT 1 September 14, 2006 04:20
