-   -   Diesel Unsteady Flamelet Error (http://www.cfd-online.com/Forums/fluent/84928-diesel-unsteady-flamelet-error.html)
jabulani February 12, 2011 13:31
Hi All,
I'm attempting to use Diesel Unsteady Flamelet for Diesel engine combustion case with CHEMKIN reaction mechanism imports. There is however an error message (shown below) when I attempt to initialise the case. Much appreciated if anyone can explain or help out.
Error Object: #f
Tox = 313 K, Tfu = 313 K, <X> = 0 /s, <p> = 101325 Pa
Initializing unsteady flamelet
Failed to calculate stochiometric mixture fraction: Assume fsto=0.5
Done.
Generating PDF lookup table
Type of the PDF Table: Nonadiabatic Table with Single Flamelet Model (Two Streams)
Calculating table .....
Error:
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Error:
Error Object: #f
AbolfazlJalalabadi June 26, 2013 16:45
Originally Posted by jabulani (Post 294967)
Hi All,
Error Object: #f
Done.
Error:
Error:
Error Object: #f
I have this exact problem, I'd be glad to know if you got this over with somehow, thanks
