Problem with Lisence file for Ansys 12 Release
Hi I installed Ansys 12 Release but when I tried run fluent from the menu programs>ansys 12>fluid dynamics>fluent this error appear to me
Loading "E:\ANSYS1~1\ANSYSI~1\v120\fluent\fluent12.0.16\li b\fl_s1119.dmp" Done. The desired vendor daemon is down. Check the lmgrd log file, or try lmreread. Feature: fluent Vendor:Host: basrah-4d8c704e License path: 1055@basrah-4d8c704e;E:\ANSYS1~1\ANSYSI~1\v120\fluent - \license tx86\..\license.dat FLEXnet Licensing error:-97,121 For further information, refer to the FLEXnet Licensing End User Guide, available at "www.macrovision.com". The desired vendor daemon is down. Check the lmgrd log file, or try lmreread. Feature: fluent-post Vendor:Host: basrah-4d8c704e License path: 1055@basrah-4d8c704e;E:\ANSYS1~1\ANSYSI~1\v120\fluent - \license tx86\..\license.dat FLEXnet Licensing error:-97,121 For further information, refer to the FLEXnet Licensing End User Guide, available at "www.macrovision.com". ANSYS LICENSE MANAGER ERROR:No servers provided. ANSYSLI_SERVERS: FLEXlm Servers: Hit return to exit. can somebody help me with it please? |
have you setup a license server and installed your Ansys supplied license file?
Yes I was installed server but my FLEXlm not running I tried install lisense file but it type me current message:
Invalid license file: The FLEXlm ID in the file did not match the system FLEXlm ID how i can solve this problem? |
So that you have all the details, please refer to the Ansys licensing Installation documentation you can get via the Ansys Customer portal. This will detail for you how to ensure that your license file was requested correctly and if you need to modify the server name or port in the license file.
This error means that the system ID you provided for your license server does not match the server it was installed on. |
Thank you mjgraf for the reply i think the problem in my FLEXlm it's not running inspite it works well yesterday but i do not know why it stopped today hence i sent you the messge that appear to me when i reread lisence manager settings hope you can help me with it:
Feb 16, 2011 18:07: Attempting to reread the license manager settings... Reread the ANSYS License Manager Settings status: Error occurred: Detecting C:\Program Files\ANSYS Inc\Shared Files\Licensing\win32\ansysli_server.exe process running on localhost. Please wait... C:\Program Files\ANSYS Inc\Shared Files\Licensing\win32\ansysli_server.exe is running on this machine. Detecting C:\Program Files\ANSYS Inc\Shared Files\Licensing\win32\ansysli_server.exe port number. Please wait... Could not find the port number where C:\Program Files\ANSYS Inc\Shared Files\Licensing\win32\ansysli_server.exe is running. Please use "-k reread port@host" to specify the server explicitly. child process exited abnormally |
either the interconnect/flexlm services are not running or there is a problem with the firewall. The interconnect and flexlm logs will provide you more information.
Follow the instructions in the Installation manual and/or contact Ansys support. Quote:
Solved the problem, there were lmgrd processes running at the back end. you have to kill lmgrd processes from command prompt and then run license, it will work fine.
| All times are GMT -4. The time now is 02:51. |
