Turbulence Model suggestion???
Old   February 15, 2011, 09:31
Default Turbulence Model suggestion???
Andy Pier
Andytzki is on a distinguished road
I am dealing with a concentric tubes heat exchanger where the inner tube is an oval twisted tube. The flow on both sides is turning due to the twisted geometry and I am trying to use the best turbulence model to solve the heat transder from one fluid to the other. I tried standard K-epsilon, realizable, and RNG (good for swirl?).
Can someone please point me in the right direction? Realizable K-epsilon gave me a nice converged answer but RNG gave me a different answer.
In case you need this info I am using velocity inlets, pressure outlets, and air as the fluid.
Thanks in advance!
Andrew
Andytzki is offline   Reply With Quote
Adding a Turbulence Model doug OpenFOAM Running, Solving & CFD 11 May 21, 2018 13:54
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
v2-f turbulence model in CFX? flga CFX 14 November 23, 2006 06:12
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 04:34
