BCs in a Tunnel Modeling
Hi everyone,
I’m trying to study the velocity distribution next to the uppermost part of a car tunnel. The problem has been described below (I know this not a precise modeling, but all I need is a rough estimation). Here is the BCs I applied: AA: 1- Moving wall (L=50 m, V=17.6 m/s) 2- Pressure-Inlet 3- Fixed wall 4- Pressure-Outlet BB: 1- Moving wall (L=100 m, V=17.6 m/s) 2- Pressure-Inlet 3- Fixed wall 4- Pressure-Outlet CC: 1- Moving wall (L=50 m, V=17.6 m/s) 2- Pressure-Inlet 3- Fixed wall 4- Outlet-vent DD: 1- Moving wall (L=50 m, V=17.6 m/s) 2- Pressure-Inlet 3- Fixed wall 4- Outflow The results are not similar, neither make sense! BTW, I solved both steady and unsteady. Also Turbulence (k-epsilon) modeling has been used. I’m not sure about 2 and 4 boundaries. Does any one know what the best BCs are? http://mehdifamouri.persiangig.com/01.JPG and here is the Computational Domain with the BCs: http://mehdifamouri.persiangig.com/02.JPG Thanks in Advance, |
Correct boundary conditions are
1 - ground - moving wall at 17.6m/s 2 - outlet - pressure outlet 0Pa gauge 3 - roof - moving wall at 17.6m/s 4 - velocity inlet at 17.6m/s assumes: >you are modelling car in an actual tunnel and not wind tunnel which has fixed relative walls >domain is large enough to allow turbulence profile to establish before impacting vehicle >upper boundary is the actual roof and not domain cut off in which case it should be symmetry >Note that wheels need MRF zones >Ensure you use prisms on car if possible and have high density wake region captured behind Hope that helps! |
