Can i open a cfx file with fluent?
HELLO TO ALL OF YOU,
I HAVE A PROBLEM IN LOADING A CFX DEF FILE TO FLUENT. I PRESS "IMPORT->CFX->DEFINITION FILE" AND IT STARTS LOADING THE FILE BUT THEN DISPLAYS THE FOLLOWING ERROR Reading "\"| utility fe2ram -tCFXD -d3 -m1e-08 \"\"C:\Documents and Settings asos\6ORUN\6orun.def\"\"\""... Error: bad syntax. Usage: utility fe2ram dimension read_format zoning write_format [inputfile [outputfile]] dimension: [-d2 | -d3 | -surface] read_format: [-tANSYS | -tCFX | -tCFXD | -tCFXR | -tCGNS | read_format: [-tANSYS | -tCFX | -tCFXD | -tCFXR | -tCGNS | -tFIDAP7 | -tFLUENT4 | -tFLUENT4UNI | -tGAMBIT | -tHYPER | NOTE: I FIRST LOADED A MESH FILE DOES ANYONE KNOW WHAT THIS ERROR MEANS? WHAT CAN I DO TO FIX THAT? |
