-   -   A CAD creation problem (http://www.cfd-online.com/Forums/fluent/85152-cad-creation-problem.html)
hamid1 February 18, 2011 07:05
Hello Duds
I am simulating two phase flow using VOF, as my second phase initial shape is complicated I canít use fluent adapt>region which only provides simple geometries, but my question is in CAD design should I create a surface of second phase inside the main geometry?
Amir February 18, 2011 10:08
Hi hamid,
for complicated problems initialization, you can use DEFINE_INIT to set initial condition of your second phase by UDF.
hamid1 February 18, 2011 11:13
appreciation for response, actually i dont want to initialize, my problem is as follow: the second phase is kind of very undefined volume means that it is not a simple cylinder or hex or cube or sphere which is provided in adapt--> region, so I should create it in CAD when I am creating all the domain there, then the question is should I create it a surface there in CAD, or in other hand how can I define a complicated zone inside CAD after the domain generation,
thanks in advance for ur clues
Amir February 18, 2011 13:07
by a UDF you can loop over all cells and according to their positions, you can set phase to that cells. you should know initial boundary position. to accelerate your UDF you can use multizone method ....
hamid1 February 18, 2011 13:24
many thanks for ur response, I also consulted with a friend and he suggested it could be possible through designing two plans in two CAD files (one for main domain and one for the second phase) and then calling them in ICEM or assembling them inside Solidworks or etc, maybe this way is more feasible/convenient,
