Home > Forums > FLUENT
force monitoring and file format
Old   February 20, 2011, 13:09
Question force monitoring and file format
Lawrence
Lawrence is on a distinguished road
Hello
I am trying to analyse the force on a pipe bend.
I have got the file written by Fluent. The problem is the data inside can not be imported into Matlab.
The file can be open by text editors but the data columns in the file are not separated.
Could somebody please let me know how to separate the data into different columes?
Thanks a lot!
Lawrence
Lawrence is offline   Reply With Quote
Old   February 21, 2011, 13:28
Robert
ral007 is on a distinguished road
Are you looking at unsteady or steady-state force data?...
How did you write out the data file?...
ral007 is offline   Reply With Quote
Old   February 21, 2011, 17:45
Lawrence
Thanks for replying.
I have been looking at a unsteady problem using Fluent 12.1. I used Solve>monitors>drag. Then the data were written out. As I set the monitor using 'per zone' and there were three zones, the data file had 4 columns which included the flow time (the 1st column), and then 3 columns of drag coefficient for each zone. The problem I got is that it is difficult to split each column off for plotting in Matlab.
Lawrence
Old   February 23, 2011, 11:38
Robert
Does the data file contain a space between columns?...
i.e. time data1 data2 data3 ... etc?..
If so, then you could try to import the data into an excel spreadsheet by specifying space as a delimiter.
Old   February 24, 2011, 06:51
Wink
Lawrence
Thanks.
Yes, there is a space between the columns. Could you please elaborate the steps how to 'import the data into an excel spreadsheet by specifying space as a delimiter'?
Lawrence
Old   February 24, 2011, 12:02
Robert
Open your excel application from start.
Then open your data file as a text file from excel program i.e. open -> file
A text import wizard will guide through the steps.
if the columns are not aligned, selected delimited otherwise select fixed.
A preview of your data file will be visible on the wizard.
Next panel choices are tab,semicolon,comma,space, and other for delimiters. Choose space.
Next panel defines data type. Select general if you have mixed characters and numbers.
Old   February 24, 2011, 17:35
Thumbs up
Lawrence
Yes! You are right. Thank you very much, Robert.
I have managed to import the data to Excel with your method.
Lawrence.
Thread Tools
Trackbacks are On
Output.fla File Morshed Main CFD Forum 0 February 12, 2009 21:00
particle tracking mike CFX 3 April 17, 2006 00:05
.run file & .info file Xobile CD-adapco 1 November 19, 2004 02:05
Force monitors Phil FLUENT 1 June 4, 2004 02:21
monitoring cell Jane CD-adapco 2 March 4, 2004 22:01
