-   -   create ring-shaped planes (http://www.cfd-online.com/Forums/fluent/85245-create-ring-shaped-planes.html)
Lilly February 21, 2011 07:51
does anybody know whether it's possible to create a ring-shaped plane at FLUENT?
I want to record some parameters in a tube cross-section and tried to create such ring-shaped planes for this reason, but I wasn't successful.
Thank you for your help!
Lilly
Will Anderson February 21, 2011 08:13
iso-clips
You will want to use Iso-Clips.
First, ensure that your domain has the correct "axial", "radial" and "tangential" directions: Cell Zone Conditions->Rotation Axis Origin->Rotation Axis Direction.
Then, create your iso-clip surface:
Surface->Iso-Clip
"Clip to values of"->Mesh
"Radial coordinate"
Set your min and max radii, click ok, and then you have the annular surface.
Lilly February 24, 2011 17:23
It is working perfect! Thanks a million!
mazdak July 6, 2012 15:31
consider a bend. at teta=45 i want to create a circular area with a diameter of
25.4mm. how can i create that with iso-clip? is it possible?
