March 12, 2011, 12:12 |
Heat transfer through 2 solid layers
Robert
Rep Power: 15 |
Hello Everyone!
I'm new here and it's my first post. I'm currently performing some heat transfer analyses in FLUENT. I want to obtain a temperature distribution in function of time in a solid body containing 2 layers: titanium and aluminum. It is an unsteady 2D analysis. The problem is that internal wall between these solids don't transfer heat. Do you know why or what boundary condition should be used there? Second question: does anyone know how to model in Fluent a thermal contact resistance ? In attachment there is a plot of current result. Thanks, Kwiaci |
March 12, 2011, 20:32 |
xrs333
Rep Power: 16 |
"coupled" type should be used.
March 13, 2011, 02:38 |
Robert
Rep Power: 15 |
Thanks,
Yes I did "coupled" there by doing two interfaces there. Now it works great. |
March 13, 2011, 06:27 |
etienne
Rep Power: 15 |
hi,
where did you find the coupled option? because i have also a problem for the heat transfer. thanks |
March 13, 2011, 13:42 |
Robert
Rep Power: 15 |
In Gambit you make two interfaces in place where two solid are in contact. Then in Fluent you use "Grid Interface" option to couple them. Next Fluent creates a new item - shadow which is interface between these two solids. In thermal options of this boundary condition there is coupled option. That's all.
March 13, 2011, 17:07 |
etienne
Rep Power: 15 |
thanks a lot
March 14, 2011, 06:28 |
sushil goswami
Rep Power: 15 |
Hi all
I am trying to simulate a concentric tube heat-exchanger in 2D. The heat-exchanger data is as given below: inlet tube internal diameter = 54mm pipe thickness = 3mm (aluminium) Outer tube diameter = 159mm Heat-exchanger height = 1000mm i have meshed the whole geometry using mapped meshing in gambit with quad mesh. I have modelled two mesh models. one with 5 zones: water-aluminium-gas-aluminium-water. Second with 3 zones: water-gas-water with walls separating the zones from each other instead of solid zones (aluminium). inlet velocity for gas = 0.5m/s with 723 K. I%= 5% & hydraulic diameter = 0.054m inlet velocity for water on left zone = 0.2 m/s with 323 K. I%=5% and hydraulic diameter = 0.052m the outer tube walls are defined as adiabatic Boundary condition. I am unable to decide the 'Boundary condition' for the walls separating water from aluminium and aluminium from gas to allow heat transfer from gas to aluminium and from aluminium to water. In 2nd geometry with 3 zones only, how should i define the 'Boundary condition' for the walls separating water from gas to allow heat-trasnfer between gas and water. in this geometry, i am defining wall thickness as 3 mm to account for aluminium. I can email the .cas & .msh files to anyone who could help. I would highly appreciate your help. Thanks in advance. Sushil |
March 14, 2011, 09:17 |
Robert
Rep Power: 15 |
Did you created "interface" boundary condition between aluminium and gas? It should help. It is very convenient way to do this. When you create interface don't merge lines in Gambit so you will get two lines coincident in one location. I hope it'll help a bit.
March 14, 2011, 12:39 |
#9 |
sushil goswami
Rep Power: 15 |
Thanks for your reply. I am kinda new to GAMBIT but i will give it a try. I would try to create interface BC for the the 2D model.
heat transfer, layers, unsteady |
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 05:43 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
No Heat Transfer between two solid domains | Mike ZH | CFX | 7 | July 26, 2008 16:50 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
