November 9, 2012, 20:31 |
question about importing a SAT file
mona rezq
Rep Power: 13 |
hi every body ,
I am architect, new in cfd work and I want to simulate natural ventilation in a building but I have a problem in converting dwg (3d) & revite files to ansys fluent , I exported the file into sat format and Imported it into ansys fluent but the program read walls as mesh so how can I convert the file correctly ? Thank u all |
November 10, 2012, 18:22 |
mona rezq
Rep Power: 13 |
thank you for reply
I am asking about how to make the mesh as I want to study natural ventilation throw a building . |
November 10, 2012, 18:28 |
mona rezq
Rep Power: 13 |
I exported the file into sat format only and I dont know wat is the next step ?
November 10, 2012, 18:48 |
mona rezq
Rep Power: 13 |
so the mesh must be drawn , wat about walls the program traet with them as mesh and wat about furniture I should remove it from mesh ?
sorry for questions but I need to understand and thank you |
November 12, 2012, 08:27 |
Jasdeep
Rep Power: 13 |
You need to make control volume, would be about 15 times the dimension horizontally and 5 times up and down. then while meshing, or if you can do in 3d modelling software itself, subtract (boolean operation) the building from the control volume. You will end up with a big box with building shaped hole inside. then mesh that box, define inlet, outlet and walls.
Hope this helps ! |
November 12, 2012, 12:01 |
many thanks
mona rezq
Rep Power: 13 |
I will try that and thank you so much
November 13, 2012, 01:10 |
#9 |
Jasdeep
Rep Power: 13 |
Also, since in your case it is a building, there will be no dimension below (obviously), the building will be on one wall. i keep space everywhere in wing study and stuff like that...
[swak4Foam] problem on installing swak4Foam | navid2 | OpenFOAM Community Contributions | 2 | May 30, 2012 04:32 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
