January 9, 2016, 12:29 |
no value changes during transient simulation
Dobromił Pszenny
Rep Power: 10 |
Dear CFD Online users,
I am working on simple 2d heat transfer and solidification model. Model contains two cell zones - layer of pcm material surrounding oil pan and oil pan itself. Steady analysis worked fine, but my goal is to examine how long does it takes for pcm to completly solidify and to see how temperature is distributed over time, so I'v changed mode to transient and set up some animation. Unfortunately, it seems like heat flow is stopped - I can't noticed any value change over time. What am I doing wrong? Cas file in attachment. https://www.virustotal.com/en/file/f...is/1452359733/ |
January 9, 2016, 17:00 |
Jura
Im having same issue. Modelling simple 3d grow-box with several vents and do want see temperature distribution over time -steady analysis works, transient not, please help
January 12, 2016, 13:03 |
Dobromił Pszenny
Rep Power: 10 |
please someone help me
January 13, 2016, 09:51 |
Rep Power: 13 |
not changing transient results mean the solution has reached a steady state. i see running wrong in that. transient results will at some time reach steady state as well.
imagine opening your rooms door, the temperature change inside the room is a transient process but will eventually reach steady state. |
January 13, 2016, 11:13 |
Dobromił Pszenny
Rep Power: 10 |
Transient simulation approach steady state after ten 10-sec time steps? Dont think so. Moreover, temperaure at both cellzones doesnt change at all and its level is equal to initialization temperature (310 K for example). Temp at whole cell zones is constant, this is not steady state
January 13, 2016, 15:46 |
#6 | |
Lucky
Rep Power: 65 |
January 13, 2016, 16:22 |
Dobromił Pszenny
Rep Power: 10 |
"Interface" between them is a wall type boundary condition. Actually 2 bc, because fluent automatically creates a shadow boundary condition - is that correct? I've set up a "coupled" condition.
animation, heat transfer, solidification, time, transient |
Transient RANS Simulation | Bazinga | Main CFD Forum | 5 | June 21, 2017 11:21 |
Question on transient simulation in OpenFOAM and FLUENT | nicklj | OpenFOAM Running, Solving & CFD | 4 | May 8, 2014 22:30 |
Transient simulation diverges | Graduation | ANSYS | 0 | February 28, 2012 07:13 |
How to integrate variable in a transient simulation? | nprace | CFX | 4 | January 9, 2012 08:59 |
Beginning a Transient Simulation | Norflow | CFX | 2 | October 7, 2011 00:38 |
