Home > Forums > FLUENT
How can i predict h-q curve of a pump?
Old   February 21, 2011, 19:49
Default How can i predict h-q curve of a pump?
Carlos Alfonso Juárez Navarro
Carlos Juárez is on a distinguished road
i am new in the use of fluent.
I need predict a h-q curve for a pump. My periodic mesh impeller was created on gambit.
I put on boundary conditions as follows.
Fluid: Water / rotation axis direction x=1 (because i put my rotation axis direction on x) / moving reference frame / rotacional velocity "3480" rpm
inlet: Mass-flow-inlet /mass flow rate: 0.323312 / supersonic/initial gauge pressure: 0 / direction specification: Normal to boundary/ reference frame: Absolute/ turbulence intensity: 5% /hydraulic diameter: 0.01896385
outlet: Gauge pressure: 791424.4 / backflow direction specification method boundary: Normal to baoundary/ turbulent intensity: 5%/ hydraulic diameter: 0.01345759 /target mass flow rate: 0.323312
peridodic: /rotacional/
i use first order discretization on flow / turbulent kinect energy / turbulence dissipation rate/
but doesn't converge the solution... what´s happening?
Carlos Juárez is offline   Reply With Quote
Thread Tools
Trackbacks are On
Pump or fan characteristic curve A Arvelo CFX 6 March 27, 2016 09:11
CENTRIFUGAL PUMP, characteristic curve Ivanrips CFX 4 September 14, 2010 10:29
Q_H curve for centrifugal pump CFD_4 FLUENT 0 October 30, 2009 06:27
How to maintain spacing along a new curve? KB Main CFD Forum 2 June 5, 2007 16:45
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
