Home > Forums > FLUENT
viscoelastic fluid
Old   February 22, 2011, 12:42
Default viscoelastic fluid
hamid
hamid1 is on a distinguished road
Hi Guys
Can fluent solve viscoelastic fluids, I have heard polyflow can do that,
Many thanks
hamid1 is offline   Reply With Quote
Old   February 22, 2011, 15:57
Amir's Avatar
Amir
Amir is on a distinguished road
analyzing viscoelastic fluids is my M.S. thesis. FLUENT can't model that. you can use polyflow that is included in ansys 12.1 and later but it's not user friendly and has some restrictions.
finally I prefer switch to OpenFOAM.
Amir is offline   Reply With Quote
Old   February 22, 2011, 19:56
hamid
U mean polyflow is another commercial code which is provided together with ansys fluent 12.1?
What are the restrictions for polyflow? Please also let me know if openfoam is user-friendly and if it is expensive to buy?
Is it possible to imply viscoelasticity through UDF in fluent?
thanks
Old   February 23, 2011, 08:33
Amir's Avatar
Amir
Hi hamid,
polyflow is a commercial software included in FLUENT 12.1 and 13.
about restrictions, e.g. it can't involve dynamic mesh with viscoelastic solvers.
but OpenFOAM is an open source code package and also free and open distributed.
it's better to use OpenFOAM under LINUX OS. to use that you should dominate on CFD schemes. codes were developed in C++ language.
for real viscoelastic flows which has elements for storing and damping energy you can't use FLUENT.
Old   February 23, 2011, 09:39
hamid
Thanks for all the helps, then as I understand openfoam is not user friendly code, is it possible to use it with windows?
If I donít have dynamic mesh can I use polyflow without problem?
Comparing polyflow and openfoam which one is easier and more straightforward to use?
Old   February 23, 2011, 11:23
Amir's Avatar
Amir
I think OpenFOAM is not user familiar but it's user friendly if you like programming.
note that you can change specific parts of polyflow by predefined macros (something like UDFs) but in OpenFOAM you can generate your own solvers easily.(it may be necessary for various viscoelastic solvers).
I prefer OpenFOAM because everything is under control unlike polyflow.
OpenFOAM was also released under windows OS but some utilities were lost and I don't recommend you.
about other restrictions of polyflow, I'm not sure, you can ask other guys about possibility of your case in polyflow.
regards,
Amir
Old   February 23, 2011, 11:35
hamid
thank u Amir for ur complete reply, I will spread out the question inside forum if I was deeper engaged with later on,
Thread Tools
Trackbacks are On
Viscoelastic Fluid Flows using OpenFOAM The solver viscoelasticFluidFoam jovani OpenFOAM Running, Solving & CFD 401 June 15, 2016 02:10
what is the value of viscoelastic parameter k for a second grade fluid? tayyab1986 Main CFD Forum 0 February 15, 2011 11:22
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 01:40
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
Viscoelastic fluid codes joel davison Main CFD Forum 0 November 6, 2001 06:09
