Error in reading case and data file. Please Help!
Old   February 28, 2011, 05:14
Default Error in reading case and data file. Please Help!
noa
anonymous
noa is on a distinguished road
My model is a 2D rectangular channel. I am able to move the upper and lower walls of the channel in constant velocity by using udf. I can run the case and look at the results. However when I try to download the results after I saved it (File>write>case and data) , the following error appear:
Error: Build Grid: Aborted due to critical error.
Error Object: #f
Error: access: unbound variable
Error Object: get-var.
Does someone can offer something???!!!!????
noa is offline   Reply With Quote
Old   February 28, 2011, 09:11
Amir's Avatar
Amir
Amir is on a distinguished road
if your velocities are constant, why did you use UDF?
if you use dynamic mesh!! it may be the result of negative volumes!
Amir is offline   Reply With Quote
Old   February 28, 2011, 10:09
noa
anonymous
I don't get negative volumes. Actually its running and I can see the results. However, when I try to download it, it says that error.
How do you do it without udf? BC with moving wall. right?
Old   February 28, 2011, 10:22
Amir's Avatar
Amir
yes, I think moving wall boundaty condition is more reasonable for your case,isn't it?
Old   February 28, 2011, 13:04
noa
anonymous
I will try do that. However it doesn't make sense that the simulation is running and the files are being saved automtically but I can't read them.
Do you have any idea?
Old   March 1, 2011, 01:59
noa
anonymous
I changed the constant velocity (in the udf) of the upper and lower walls of the channel to time dependent velocity. I can saving the data and case but I am not able to read it.
Can you think why????
Thank you
Old   March 1, 2011, 07:46
Amir's Avatar
Amir
I have to suggestions:
1)keep velocities constant and check whether your problem exists!
2)if you interpreted your UDF, try compiled one and check!
Old   March 6, 2011, 04:26
noa
anonymous
I realized my problem. I used dynamic mesh to move an interior wall. The case was running but couldn't be read after I saved it. When I changed my model and moved the wall (not as an interior), it was able run, save and read.
[Commercial meshers] Problem converting fluent mesh vinz OpenFOAM Meshing & Mesh Conversion 28 October 12, 2015 06:37
Error reading new case montag dp FLUENT 5 September 15, 2011 06:00
Changing the grid on the same set-up Katya FLUENT 7 October 8, 2009 16:31
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
Reading data file MON FLUENT 4 September 20, 2002 14:25
