-   -   Airfoil Average Nusselt Number calculation (http://www.cfd-online.com/Forums/fluent/85631-airfoil-average-nusselt-number-calculation.html)
y2k_o__o March 2, 2011 23:46
Hi everyone my current version of ANSYS Fluent is 12.1
The type of flow I am using is a Spalart Allarmaras Model
Please correct me if I am wrong
Now, I wantwant to calculate an average nusselt number from the Solution
so do I just simply click "monitor" -> " Surface Monitor"
Report Type: Integral
Field Variable: Wall Fluxes, Surface Nusselt Number??
and also how do I calculate the Reynolds number of the flow as well ?
Thanks =)
y2k_o__o March 3, 2011 01:25
I have the Nusselt Number Distribution around the airfoil
does the Nu Distribution look like that ?
http://i40.photobucket.com/albums/e2...lotgrid100.jpg
and how do I average them ? just add them all and divide by the number of point, n ???
ps: this airfoil is a unit length airfoil
Thanks
Amir March 3, 2011 03:41
before computing Nu No., be sure that your reference values are correct.(report->reference values)
I think for evaluating average Nu No., you can compute total heat transfer from airfoil and then obtain an equivalent h(heat transfer coefficient) and then compute Nu.(just a suggestion)
y2k_o__o March 3, 2011 04:47
Originally Posted by Amir (Post 297730)
Yes I've checked the reference value are the correct for air properties
as far as obtaining equivalent h from total heat transfer...
what delta temperature should I use ?? ( Temperature varies along the chord length too)
Thanks,
Amir March 3, 2011 05:21
Thanks,
I think it's a good idea to use dT=(Tave-Tinf). you can obtain Tave from report->surface integral->average facet. isn't it?
y2k_o__o March 3, 2011 06:45
so what you're saying is:
h_avg = overall_heat_transfer_rate / ( T_avg - T_fluid )
Nu_avg = h_avg * chord_length / k_fluid
Amir March 3, 2011 08:37
yes, it's right if T_fluid & k_fluid remain constant during solution.
