Pipe Flow Analysis
Old   March 4, 2011, 05:32
Default Pipe Flow Analysis
Akshayy Garg
akshayygarg is on a distinguished road
Hi
I am a beginner in FLUENT. I was doing pipe flow analysis and having problems with the solution.
Problem.
Pipe - 5m long, 66.7 mm dia.
Inlet pressure - 60 bar (static).
Outlet pressure - 8 bar (static).
Fluid - air.
T -300 K.
To do flow analysis as well pressure exerted by fluid on walls.
Solution I did was:
I made a 3-D pipe in gambit and loaded it on FLUENT. I used the laminar conditions initially just to get an approximate result. air is considered incompressible. Pressure at inlet kept at 60 bar as well as static at 60 bar. Pressure at outlet kept at 8 bar.
I still do not get results with static pressure varying on wall from 4.7e12 to -2.93e12 which is not possible.
Plz help I am new to this.
Akshayy Garg
akshayygarg is offline   Reply With Quote
Old   March 4, 2011, 07:49
ThanhToan
trantoan2008 is on a distinguished road
Send a message via Yahoo to trantoan2008 Send a message via Skype™ to trantoan2008
Originally Posted by akshayygarg View Post
Hi
Problem.
Fluid - air.
T -300 K.
Solution I did was:
Akshayy Garg
I think you need check your unit system which you used for your solution.
Hope help you.
Best regards,
Tran
trantoan2008 is offline   Reply With Quote
Old   March 4, 2011, 07:59
Akshayy Garg
I am using i-5 processor, 2 gb ram, win 7 home premium-32 bit
Old   March 4, 2011, 08:57
ThanhToan
Your computer is so good for computation time. However, I mean that you need check unit solution such as SI,...
Turbulence intensity in fully devloped pipe flow - Reference Shocktrain Main CFD Forum 0 October 14, 2010 06:58
Blood flow through pipe kmgraju CFX 1 August 4, 2010 02:36
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 03:11
Domain for Pipe Flow Swarup FLUENT 0 September 28, 2005 23:25
flow in pipe with momentum and energy source Atit Koonsrisuk CFX 3 March 29, 2005 16:58
