Turbulent Viscosity Limit but only showing for imported case
I know getting the error message about the Turbulent Viscosity ratio being limited is very common but I think my particular problem with it is not quite as usual. If I run a calculation and then reset everything from the setup downwards and then reset the setup to the new values that I want for my next calculation, then this problem does not occur. However, if I click on setup after running a previous calculation and without resetting everything first then I get the message about the turbulent viscosity ratio. The same thing happens if I import a case file which has been previously run. It is very inconvenient that I should have to remesh etc. each time I want to run a calculation on a different setup so I was wondering if anyone had a different solution? Any help would be very much appreciated, thanks. |
