phase transition simulation
Old   March 15, 2011, 03:37
Default phase transition simulation
jcdx is on a distinguished road
Hi group,
I have a question about the possibilities of Fluent.
Consider you have a box filled with an alloy of 2 salts. From the outside you define a temperature that is above the phase transition temperature of the alloy, i.e., the alloy will start to melt.
The question is can I model this process including the time development of the melting front as it moves from the outer surface to the core of the salt?
Can I model the temperature distribution dynamically?
Do I need user defined functions for this kind of simulation?
Thank you very much in advance!
JC
jcdx is offline   Reply With Quote
simulation two phase closed thermosyphon mohammad reza FLUENT 3 November 1, 2016 03:58
flow simulation with a fixed transition point? cfdzou FLUENT 2 March 4, 2016 22:05
Three phase simulation of airlift reactor Idtisak CFX 0 February 22, 2008 10:05
multi phase simulation Thandavan CFX 4 June 28, 2006 23:29
time and phase averaging simulation data prem FLUENT 0 December 28, 2003 22:15
