Home > Forums > FLUENT
(ASK) negative pressure detected on my outlet.
Old   March 21, 2011, 04:27
Default (ASK) negative pressure detected on my outlet.
wibi ario
sincity is on a distinguished road
hi friends
i'm modeling butterfly valve plus pipe in FLUENT 6.2, after i had my simulation then i display my pressure contour, i got my pressure was negative on the outlet, why that happen?
regards,
sincity is offline   Reply With Quote
Old   March 21, 2011, 04:40
Amir's Avatar
Amir
Amir is on a distinguished road
note that you've used gauge pressures.
Amir is offline   Reply With Quote
Old   March 21, 2011, 06:43
wibi ario
i dont have any data about gage pressure, one that i know for sure is just open loop with the asumption that static outlet pressure is 1 Atm. how bout that??
Old   March 21, 2011, 10:50
Amir's Avatar
Amir
ok, your outlet absolute pressure is 1atm. ensure that you set operating pressure correctly. your absolute pressures are evaluated relative to operating one. and double check your boundary conditions.
Old   March 21, 2011, 22:13
wibi ario
i set the operating condition in 1Atm, is it correct?
my boundary condition is velocity inlet and pressure outlet
Old   March 22, 2011, 03:32
Amir's Avatar
Amir
then you should set gauge pressure in B.C. panel at the outlet. if you have static absolute pressure of 1 atm at the outlet set 0 pa there.
Old   March 22, 2011, 05:09
wibi ario
that's what i did, my friend amir but the pressure still negative, why?
Old   March 22, 2011, 08:22
Amir's Avatar
Amir
if you set outlet gauge pressure to 0 pa, the pressure in all cells should be positive unless for supersonic flows or when your case doesn't converge yet. check whether the pressure at the outlet is zero or not and also check residuals.
Old   March 22, 2011, 08:38
wibi ario
i have my case converged obviously. yeah i have checked it and the outlet pressure is zero. any idea what was going wrong? my reynold number is 449.500
Old   March 22, 2011, 08:51
Amir's Avatar
Amir
so, it may happen just after a valve because of separation zones and after that pressure increases to zero at the outlet.
Old   March 22, 2011, 11:58
wibi ario
is it normal?does it make a sense?
Old   March 22, 2011, 13:30
Amir's Avatar
Amir
yes,
after separation zones it usually occurs.
Old   March 22, 2011, 21:30
wibi ario
yes dear my friend amir i know it usually occurs..cavitation and cavitation is always obtained in the zone where the pressure is below the atmosphere but could it be possible reach negative value???
Old   March 23, 2011, 03:17
Amir's Avatar
Amir
your gauge pressure in those zones is negative not absolute one. (e.g. if you get -1000 pa, it means that your absolute pressure there is 100325 pa) it just shows that pressure there is lower that the value at the outlet.
Old   March 23, 2011, 05:07
wibi ario
so how about if the pressure is positive? for example my inlet pressure is 550.673 Pa, it means that the absolute is 101.325 + 550.673 Pa, right??
Old   March 23, 2011, 08:46
Amir's Avatar
Amir
yes, of course.
Old   March 23, 2011, 10:07
wibi ario
what an interseting conversation with you, thanks amir may Allah bless you, are u moslem?
Old   March 23, 2011, 10:15
Amir's Avatar
Amir
you're welcome.
yes I am.
Old   March 23, 2011, 11:56
wibi ario
me too.
amir
Thread Tools
Trackbacks are On
ZeroGradient pressure Outlet BC prob (adjustPhi.C) Stylianos OpenFOAM 3 March 23, 2010 13:28
seeking for help about a room with negative pressure mengyue1 FLUENT 0 November 26, 2009 07:40
negative static pressure Selo melo FLUENT 5 December 18, 2006 10:30
negative pressure mAx FLUENT 0 January 25, 2006 15:31
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
