-   -   problem in sealing inter chamber leakage in wankel simulation (http://www.cfd-online.com/Forums/fluent/86425-problem-sealing-inter-chamber-leakage-wankel-simulation.html)
pravin.iitk March 22, 2011 12:22
Hi all,
I need little help in sealing inter chamber leakage in wankel simulation. I am trying to impose momentum source (sink) near rotor tips. I wrote udf code but it doesn't seems to work at all. If anybody can help please.
Thanks in advance
Catthan August 18, 2011 10:31
Hi pravin.iitk,
I'm very sorry to divert your thread as I don't have an answer to your problem and I really hope you have solved it by now.
I am seeking for advice on setting up a dynamic simulation of the gas circuit in a Wankel engine; no combustion, just the rotor motion and the mesh deformation.
I have a UDF for moving the rotor CG on a circular path, the radius equal to e, which seems it works but I'm getting negative volume errors and I can't sort out how to define the dynamic mesh zones. The only thing I'm sure about is setting the rotor as a rigid body.
The mesh is hexahedral and consists of the rotor and housing surfaces and a top and a bottom surface to enclose the volume mesh.
I would be very grateful if you could help me.
All the best,
