VOF convergence issue
Old   December 9, 2013, 07:58
Smile VOF convergence issue
Rams Manu
manxu is on a distinguished road
I am using a VOF model to simulate water droplet motion by applying a body force. I am using :
- VOF Explicit + CICSAM + PRESTO
- Body force = gravity. (using the implicit body force formulation increases the time for convergence. SO I switched off the formulation, though I have gravity)
- Specified operating density = 0 (since air and water are present)
Mesh size is 2microns and time step is 1e-8. Even if I have 200 iterations per time step, it goes through all the 200 iterations per time step without reaching the absolute convergence (fluent default) point.
Is this OK as long as it doesn't diverge or should I increase the no. of iterations per time step ?
P.S: I tried reducing the time step to 1e-9, still no convergence. (no divergence either)
Thanks
manxu is offline   Reply With Quote
Old   December 10, 2013, 16:12
Zaktatir is on a distinguished road
What about the boundary condition! and The reference of your pressure
Zaktatir is offline   Reply With Quote
Old   December 10, 2013, 21:51
Rams Manu
All the boundaries are pressure-outlets with only one wall at the bottom. The reference pressure is 101325Pa at 0,0.
Old   December 11, 2013, 14:42
your mesh is very fine and if spurious velocities are great then you won t mange to avoid them. By the way what about the surface tension force!
THE CSS is phyically more conservative and may enhance stability.
Do you want to make a DNS very resolved simulation i find your mesh very fin? How big is the droplet?
I simulated a couple of weeks ago for some folks the spreading and the impact of droplet on the wall and it was high converged
Old   December 11, 2013, 21:53
Rams Manu
The droplet's radius is about 50microns. Yes surface tension force is quite important but the body force is larger than surface tension forces.
What is CSS and do u think that the parameters/discretization i used are correct ?
Old   December 12, 2013, 20:30
beer is on a distinguished road
Hi
I find it often helpful to use the selective AMG solver as well as ILU and BICGSTAB instead of the standard smoothing and solving of the differential equations. I had a few interesting convergence improvements in multiphysics in the past.
Best Regards
beer is offline   Reply With Quote
convergence criteria, vof model
A Peculiar Convergence Issue pano Main CFD Forum 0 February 18, 2013 14:16
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX shiyun ANSYS Meshing & Geometry 4 May 9, 2012 19:55
convergence criterium for unsteady 3D VOF jack1980 FLUENT 2 February 28, 2010 09:04
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
VOF model convergence lana FLUENT 11 October 1, 2005 05:23
