Parallel running of Fluent
Old   June 11, 2007, 04:49
Default Parallel running of Fluent
Bhanu Gupta
I want to run Fluent in parallel on clusters. We have 16 nodes connected to each other and want to run Fluent in parallel and are not able to do so. Intially after setting condition in Fluent on Run menu and Configuring it. It was asking for passowrd while going to other node which it should not as was told by someone. Then after some modification in rsh file as working on linux os we overcomed that problem but still it says unable to connect the host. Please give some suggestion what can be done to run Fluent in parallel.
Bhanu Gupta M. Tech (Thermal) IIT Delhi Hauz Khas Delhi- 110018
Old   June 11, 2007, 06:57
Default Re: Parallel running of Fluent
ritmat
i run fluent with windows and i just followed the fluent tutorial.
Old   June 11, 2007, 09:08
mAx
hi, take a look at following link. I have made my own cluster following the instructions and it works. Hope it helps http://www.mcsr.olemiss.edu/bookshel...r.html#Master1
Old   April 7, 2011, 09:32
Default Basics of clusters
Anand S. Biradar
Anand S. Biradar is on a distinguished road
Can you help me in making the cluster of two Laptops for Fluent parallel solving. I want to solve 3d Vertical Axis Wind Turbine Problem. (Windows 7, Ansys 13 installed on both with Intel MPI software).
Anand Biradar
9960659400
B.E. Mechanical, Wadia College Pune
Anand S. Biradar is offline   Reply With Quote
parallel fluent runs being killed at partitioing Ben Aga FLUENT 3 June 8, 2012 10:40
running a journal file in Parallel FLUENT novice FLUENT 0 June 15, 2010 04:19
Parallel speedup Fluent Gigabit Ethernet Myrinet etc tehache OpenFOAM Installation 5 September 7, 2009 05:51
Fluent parallel poovanna FLUENT 0 March 23, 2007 23:22
Parallel Fluent with Mandrake Daniel Dotta FLUENT 1 May 19, 2005 15:30
