# Divergence detected in AMG solver: temperature -> Increasing relaxation sweeps!
Hi all,
I'm a novice at FLUENT, and i'm having trouble getting my solution to converge. I'm trying to do a heat transfer analysis on a 3D mesh, and I keep getting this error: # Divergence detected in AMG solver: temperature -> Increasing relaxation sweeps! I've tried changing the URF and the limit of the temperature. Any ideas? |
try to reinitialize the solution, using more physical values, espacially for turbulent variables. you can check up turbulent viscosity ratio after initialization, it should not be too large.
dirvegen detected temperature
I have the same problem. The project is about super sonic flow over a surface. we have the Tu%= 0.1. the speed of M=1.4 the gauge pressure is = 771643.9 Errors : when the solution initialized it shows: turbulent viscous ratio limited in some cells absolute pressure limited temperature limited can some one suggest me the solution. |
pastarox try :
solution controls -> advanced -> set cycle type to F cycle .. Giving non physical source terms / boundary conditions may also cause it .. i had the same a coupe of times |
Abhya, Can you explain what is non physical scource tearm. The changed cycle type is F-cycle but not working.
Now i'm getting absolute pressure limited.. can some one direct me or tell me why i have the problem. I checked my grid it look good too.. |
For example : I had a mass source term and an energy source term which depends on the mass source term as: Energy source= (-mass source)*latent heat I had forgotten the -ve sign earlier and this resulted in the error as yours... |
I m also new to CFD when i do the compute solution the it always shows divergence detected error.
i m using following boundary conditions: 1) velocity inlet with velocity 50.37m/s and temperature 303k 2) pressure outlet with atm. pressure 3) energy equation on 4) constant heat flux on wall 1400W/m2 |
hello friends
I getting this error: # Divergence detected in AMG solver: temperature -> Increasing relaxation sweeps! I check mesh and because of pressure-base solution I cant change relaxation factor and also change solution control but it didn't work please help me |
