Home > Forums > FLUENT
CD error!
Old   April 1, 2011, 06:10
Default CD error!
NLao is on a distinguished road
Dear all,
I am using the inviscid solver in Ansys Fluent to solve a 3D rectangular planform wing, with a chord of 1 metre, semi span of 8 metres and using a NACA0012 aerofoil profile. Inlet velocity = 29.5069 m/s (Mach 0.1 at 216.65K).
Boundary conditions: Wall (Wing), Symmetry (Domain Walls), Velocity Inlet (Around the domain).
At 5 degrees angle of attack, I am obtaining values of CL and CD of 0.512 and 0.006, respectively.
I have used XFLR, to analyse a 3D wing using the viscous Lifting Line Theory method. The values i get from XFLR are CL=0.5051 and CD=0.0145.
The CD from XFLR is both the profile drag and the induced drag. So using the lifting line equation for induced drag
(CD,i = (CL^2)/pi*AspectRatio*SpanEfficiency)
the CD,i = 0.01252
This shows a 52% error from the result I obtained from Fluent compared to XFLR.
Does anyone know why I am getting such a large error in CD?
This is a major issue for me, as I am trying to analyse the affect of wing tip blowing to reduce the induced drag on a wing.
If anyone could shed some light my problem, I would very much appreciate it.
Thanks
Lao
Nevermind, I solved the problem.
NLao is offline   Reply With Quote
Thread Tools
Trackbacks are On
GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM 300 October 29, 2014 19:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 18:43
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
