April 4, 2011, 04:30 |
meshing a wind sail
Linyx
Rep Power: 15 |
Hi, everybody
I have a problem in meshing a 3d ship wind sail in gambit. I create the geometry in 2d and then sweep it. Then i create a cube as the compute domain,see picture . finally, i subtract the cube with the wind sail. here come the question that how i can mesh these things? regarding it is symmetry, i cut them into two from middle. if i use TGRID/tet-hybrid, it would be costy and the meshing quality is poor. can anybody tell me about a good scheme(such as multigrid) of meshing in 2D so that i can use the cooper scheme? I really appreciate if you can give me some advices. |
April 4, 2011, 04:36 |
addings
Linyx
Rep Power: 15 |
yet,another problem, the soft sail is very thin, can i regard it as an edge in 2d or just a face in 3d? it seems that the gambit can not handle such a problem as it is a lower dimension.....is it true ?
April 4, 2011, 05:32 |
Maxime Perelli
Rep Power: 41 |
you can try using size functions for instance
http://my.fit.edu/itresources/manual...g0502.htm#1735
In memory of my friend Hervé: CFD engineer & freerider |
April 4, 2011, 23:15 |
Linyx
Rep Power: 15 |
do you know how to mesh the multi-element airfoil like pic1 in structured mesh in gambit?
April 4, 2011, 23:16 |
#5 | |
Linyx
Rep Power: 15 |
April 5, 2011, 05:12 |
Maxime Perelli
Rep Power: 41 |
by dividing the domain into smaller and logical subdomains (>>splits)
April 5, 2011, 10:39 |
#7 | |
Linyx
Rep Power: 15 |
thanks a lot for your advice! |
April 6, 2011, 03:57 |
Maxime Perelli
Rep Power: 41 |
check tutorials first
http://my.fit.edu/itresources/manual...guide/tg04.htm this one explains how you can divide your domain into logical subdomains
Display Modes | |
Wind tunnel hexa meshing in ICEM CFD 12.1 | matheusguzella | ANSYS Meshing & Geometry | 1 | March 14, 2011 17:14 |
simulate wind tunnel and meshing....need some help | ACER | FLUENT | 0 | December 27, 2010 17:02 |
Wind turbine blade meshing | caohan | FLUENT | 12 | April 22, 2010 11:49 |
Meshing of a 2-D Sail Model | ersahino | Siemens | 2 | April 9, 2010 17:45 |
Meshing Wind Tunnel | Nazo | FLUENT | 0 | October 18, 2007 11:24 |
