with or without dynamic mesh
Old   April 5, 2011, 05:32
Default with or without dynamic mesh
raymond
wlt_1985 is on a distinguished road
I would like to model the interaction of fluids in a tank. Those fluids are immiscible and interface appears between them. When there is a motion to one of the fluid, the moving fluid should have motion and the interface should be moving instead of stationary. I am going to model it with VOF. Just the problem is: Should I use dynamic meshing in this case? If anyone does have the similar example on this case, can please send me the detail of modeling this case? Thanks for your help.
regards
wlt_1985
wlt_1985 is offline   Reply With Quote
Old   April 6, 2011, 00:45
Sushilkumar is on a distinguished road
It's not required to get the dynamic mesh. If you wish to capture the interface accurately you can use mesh adaptation.
Sushilkumar is offline   Reply With Quote
Old   April 6, 2011, 01:01
raymond
Sushilkumar,
Thanks for your help. I am new to CFD and do not familiar with mesh adaptation. Can you please give me a brief explanation on how to operate it or do you have any tutorial regarding on it? Thanks a lot for your help.
regards
wlt_1985
Old   April 6, 2011, 01:23
raymond
Sushilkumar,
Thanks for your help. The following link showing the model I would like to study and it might provide clear configuration.
http://www.youtube.com/watch?v=tdO_ePSdYkY
Do you have any idea to get the model to study on it?
Thanks a lot.
regards
wlt_1985
Old   April 6, 2011, 07:58
Hi wlt,
If I am not wrong, the link shows the model simulated with FLOW 3D and not Fluent. If you consider this model then simulation in Flow 3D is much easier than in fluent. As moving component model and free surface model can be easily set in Flow 3D.
However, this can still be modelled in Fluent too, but need little more efforts.
for mesh adaptation you can find the respective tutorial in tutorial guide.
Old   April 6, 2011, 08:05
raymond
Hi wlt,
Sushilkumar,
Thanks for reply. I agree with you that in order to make the work easier, FLOW 3D shall be the best choice in order to study my model. I am using FLUENT just because my company does have the license of FLUENT and we are using FLUENT instead of FOW 3D. Hence, I try my best to model it with the FLUENT. Any idea to study my model with FLUENT?
Thanks for help.
regards
wlt_1985
Old   April 6, 2011, 08:08
Originally Posted by wlt_1985 View Post
Sushilkumar,
Thanks for help.
regards
wlt_1985
Are you planning to use moving mesh?
Old   April 6, 2011, 09:01
raymond
Sushilkumar
Thanks for reply. I would like to study my model as best as possible. Hence, I am looking for the best way in modeling it. I found that dynamic meshing shall be the best way in studying my model. However, I am not sure about it and do not know how to operate the dynamic meshing since it might be complicated and time-consuming. Therefore, I am looking for suggestion in this forum. Do you have any idea in order to make it the best?
Thanks for help.
regards
wlt_1985
Dynamic Mesh on Pintle type injector. herntan FLUENT 16 September 4, 2020 08:27
Incylinder dynamic mesh with volumetric reaction mas FLUENT 4 May 3, 2012 10:22
dynamic mesh on a hexa grid Manoj Kumar FLUENT 0 August 21, 2007 07:41
Dynamic mesh + grid adapt = Crash! (Files included BillH FLUENT 4 July 24, 2007 15:31
Help: Is it possible to use dynamic mesh model and Valery Ponyavin FLUENT 1 September 20, 2003 14:18
