Error:open_udf_win64-bit
hello,
i am trying to simulate flow through a radial turbine wheel using dynamic mesh in fluent. i could compile my UDF in fluent 6.3.26(32-bit),but because of low memory(maximum=4Gig)in this windows,i couldn't run my case. i want to compile my UDF in fluent 6.3.17(64-bit),but in compiled Udfs box,when i attempt to add UDF,in fluent issues fatal signal error. so enyone know how can i solve this problem? with kind regards,mamy. |
you have to set environment (e.g. lib , include, path) before compile UDF.
Dear mamyjooooon, What version of 64 bit window are you using? Window 7 professional or any else? I am working on window 7 professional 64 bit operating system. During the installation of 6.3.26 (64 bit), message appears as below: This installation does not support window operating system.......(seem like do have compatibility issue) Did you fae the same problem as mine before? How you solve it? Thanks for help. Best regards |
